Did you try to set infill to 0 and disable top bottom fill and then increasing shell thickness really high? that should give you perimeters only. but I guess that is not all that you are after?
@DidierKlein : Actually the model is already hollow, it's a shell with a thickness, and this aspect cannot be modified as the files are generated through a larger process that doesn't allow me to work with a closed body and then hollow it.
@Avogra : I tried both, but they're not working (or at least not the way I want to) : I do need a solid top and bottom (I could use SwapatZ to only have to bottom and top solid and don't have it on the overhangs that Cura would consider to be a top or bottom), but if I set the infill to 0 I would end up with some gaps. Setting the perimeters really high does generate only perimeters, but again, they're not spaced in an optimal way that would make them the exact thickness of the shell for that specific layer, so I always end up with some gaps and some perimeters lines not touching.
What I would like to achieve is to have Cura (or again another slicer, I like Cura but wouldn t mind at all switching to a different one if needed) determine for each layer the right perimeter/shell width in order to have each layer printed with only perimeters without leaving gaps so that it would only be touching lines (which is better for both translucency and strength). The only thing I can think of for now is to tweak the extrusion width by hand for different areas and use SwapatZ multiple times to achieve that, but this would take a crazy amount of time to set up for each part, and would also not give perfect results as in theory I would need to tweak the value for every single layer (which would then take an insane amount of time ..).
Any suggestions on how to achieve that without having to spend a day doing the slicing setup ?
DidierKlein 730
Hi and welcome,
Maybe you could try to hollow the model (with meshmixer for example)?
