About the pictures, it could be because you took the pictures with your phone? The forum reads the orientation and rotates it to what it thinks is right. But it isn't always.
It should have been fixed last week, let me forward this to our dev's.
Care to share some more pictures of your feeder?
Have you used the original feeder and mounted it on the original feeder motor but from a different angle from the frame?
What is it that you mounted on the feeder which is on 2 of the 3 images?
Hi SandervG
Yes ! pictures was took by phone.
I still use the original feeder and its motor, had not yet encountered any particular difficulties I just concentrate for now on the routing of the filament in the Bowden tube.
I found that the filament is still rigid enough so that the tube and all demand significant efforts in all motors and more particularly to the feeder one.
Making the feeder pivoting requires less displacement XY force of the print head greatly and improves the sliding of the filament, being already naturally curved in the curvature of the Bowden tube, with the marking made by the knurled wheel being at the inside of the bend.
I found that the printer is considerably less noisy, the X and Y movements are softer and very sharp. All the engines are less hot than before.
Noting that there is great radial pressure working on the knurled wheel, I also added a bearing hub to the original feeder body it supports the end of the motor shaft thus eliminating the overhang of the drive shaft that will suffer less while benefiting from more torque to push the filament.
For now I have only printed the PLA, it will certainly be a different story for other types of materials !!!.....
gudo 246
Hi SandervG
gudo 246
a short video
