UM2 Analog port- help
sergiucip
Posted · UM2 Analog port- help
Hello,
I need help to connect a sensor to analog port on Ultimaker 2 board.I want to connect a hieght sensor for autocalibration .
My sensor have the following pins to connect to he motherboard (VCC 5v, GND and 3.3 Volt Output) same as analog port on the UM2 motherboard.
I need some info about where to look for pins.
Thank You!
