S3d, octoprint, um2+ fans not turning off when print/cooling finished
vince805
Posted · S3d, octoprint, um2+ fans not turning off when print/cooling finished
I slice with s3d and print using octoprint and when the print is finished the bed goes down, the head homes and the head/bed temps go down but the fans will keep blowing and blowing and blowing.
When I used to print from the sd card I think the fans would turn off eventually. Maybe I should test that. Any other ideas?
    • 2 months later...
    You'll need to edit your "After print job completes" GCODE script in the printer settings section of Octoprint. This is what I'm using:
    G28 X0 ; home the X-axis
    M104 S0 ; turn off heaters
    M140 S0 ; turn off bed
    M107 ; turn off fan
    G28 ; home all
    M84 ; disable motors
