cloakfiend 995
You probably just have a slow jam, your prints look good. Do like a million atomic pulls and try it again. If youre worried its the pfte then just change it, but i found that the pfte is dead only when i cant do any atomic pulls.
Nozzle clogs are not so simple to see with abs btw, its always more visible with pla, as it melts at lower temps, and its the lower temps which cause the jams. I dont print 0.1 much so cant advise you on that, but another thing i would do if i wad you would be printing hollow (zero shell, as for small stuff you dont need it, just make the shell a bit thicker my default is 1.2 for everything. Its never failed me 0.8 has failed me loads and i never go below 1.2 now.
Nicolinux 288
Did you check the PTFE coupler? It is different from the UM2 but could be damaged/deformed. You could check the filament too. If the diameter changes regularly (on every loop), this would explain why it always clogs at the same spot.
