One is in the advanced menu and called top / bottom speed. If this is set to 0 then it will print at the normal print speed. If a number is entered it will print at that speed.
The other setting which can cause it and the problem it think you have with the ears is called minimum layer time. If one layer will take less then this time it will slow the print speed down till it takes the amount of time set in this layer time setting.
This is to try and prevent the printer from putting down another layer when the previous layer is still hot. This setting can be good and bad as the hot nozzle travels slowly and it can over extrude. So you can adjust this but you may experance over heating. The best way to fix this it to either print 2 items at once (if they are small) or print a small tower next to the print.
Labern 775
There are 2 settings that can cause this.
