I'd raise the bowden until you can see the end of it and make sure it goes down another mm or so *into* the teflon part.
I never looked at the hours printed. That's cool, thanks for letting me know about that feature. I'll check it out. Last night I removed the PTFE coupler and it looked bad. I think you were right, my coupler looks deformed on the top and was not allowing the bowden tube to insert all the way. I'm ordering a new coupler today.
Order it from my store then: gr5.org/store/
gr5 2,192
I don't get the bulbous head. Is your bowden tube all the way down? Not UM2+, right? You should be able to see the bowden through the spring and tell if it's all the way into the white teflon part. If it is well seated then I'd guess it's your ptfe coupler. How many hours have you printed on this coupler (you can check in the menu system for hours printed if that helps) and what temperatures do you usually use (max) for prints that are on the high end of the temperature spectrum for you?
