Posted (edited) · UMO Direct Drive solution
I am thinking about UMO direct drive solution. I've found here that prefered one is with stepper motor directly connected to the shaft (letter A on the example). But what about hiding motor on the back of UMO and connect it to the shaft directly via 2 identical gears ((letter B on the example).
examples here:
What are your opinions about solution B? is it good/bad etc? what are its prons / cons?
    I am a big fan of your thoughts about hiding away the stepper motors... Them sticking out, on the outside of the printer, is my main reason for not doing a direct-drive setup...
    Regarding your design, you would probably want to use something like a herringbone gear to avoid any play in the gears when turning direction... I would still be afraid that the gears could be quite noisy when printing at speed, maybe you can compare with some similar setups like the Tantillus:
    Posted · UMO Direct Drive solution
    great example, for such setup, haven't seen this printer before.
    About noisy gears I think I can print gear covers to hide them and reduce noice if it will happen. Gears on the image are only for example purpose. Herringbone gears are must as you said.
    I think about the setup in which one motor will be geared (for the back shaft) and the second probably connected directly to the right shaft. I want to remove motors from inside of hot chamber which I will probably make some day, and hide them on the back of printer.
