Posted
· Printing problem and Stopped Temp Sensor BED
Hi Luc,
check for any loose wires at the back of the heated bed. Also take off the board cover at the bottom of the printer (it is by two screws only) and inspect the board for any loose or broken connections.
Nicolinux 288
Hi Luc,
