Posted
· Why does Cura have weird 100% infill zone?
This is near the top of this section of the part and you have top/bottom thickness set to 3mm. Which is a lot! .9mm should be plenty. or even .6mm. If you want the tops of your part to be hollow then set this value to zero - or just do it for an experiment and see what happens in layer view.
gr5 2,224
