Which bootloader does the UM2 firmware use?
jayeye
Posted · Which bootloader does the UM2 firmware use?
Before I brick my UM2... I'm successfully building github.com/Ultimaker/Ultimaker2Marlin/Marlin at SHA dabb1c under Arduino 1.6.8.
Questions:
  1. Which bootloader should I use?
  2. I assume the various settings in Configuration.h are for the UM2 (at least the thermal settings and the display settings are. How about dimensions?
  3. Is this the repo from which the production version of the firmware is built? If so, would it be possible to upload the various configurations used to produce the standard firmwares distributed with Cura?
Thanks,
/ji
PS: Thanks to Daid for making the simulator available!
