For whatever reason, I was finally able to connect to the Duet last night. I don't really think I changed anything. I just kept trying and it finally worked.
However, there's still an issue. I was able to jog the printer just fine from Cura but when I tried to print something the hotend wouldn't move. I'd see the progress bar moving as if Cura thought it was sending data and it was being executed but there was never any movement from the printer. Strangely enough, I've been helping a friend who is building a Cartesian printer based on the RAMBo controller who is having the exact same issue (can jog but not print). We thought it was a printer issue but maybe its a Cura issue. Ideas?
Thanks,
Ian
nallath 1,125
I'd try it with auto baud rate. It's probably using the wrong one.
