Posted · Slicing Error with Cura 12.11?
I wanted to print the polygon mask from Thingiverse (
http://www.thingiverse.com/thing:33505
) and sliced it with Cura 12.11. For large objects I normaly use 0.24 layer height, 0.8 wall thickness, 15% infill. You can find my profile here.
At the begining everything looked fine:
This is layer 334. You can see two walls (= 0.8mm) and the infill. But then just a few layers later...
... at layer 341 there is only one wall (= 0.4mm). This continued for another 100 layers and pretty much screwed up my print.
Has anybody an idea what happend during slicing? Why did cura change to 0.4mm wall thickness? :?:
