Thanks for the tip. But I only found white little spacers. 4 each of slightly different size. 4 are just round tubes, the other 4 are hex shapes with threats inside:
https://www.dropbox.com/s/ealtjeu69idm2jv/20121121_124336.jpg
Are those correct and if so how do I use them exactly, since 4 are longer than the other 4.
Edit: Never mind, found the 8 black spacer pieces. Thanks.
Daid 303
The assembly instructions where not updated for some changes in the kit, they will be soon.
Instead of the 7X parts you need to use the little black spacers. They are these black round things of 11mm in length.
(Note: This change was done to reduce noise)
A few other changes where done at the filament drive, but this should assemble the same, just look slightly different. This will also cause a noise reduction, and will make it easier to open/close the filament drive.
