I am not an expert with printing ABS, but I did print with ABS on a similar 3d printer. What I found out is that ABS needs to be hotter than PLA to stick to other layers. The heated bed can also be replaced with a "raft", which will give waste but you wont need a heated bed. Only need to make sure that the raft sticks to the bed. (I used an acrylic bed, but balsa seems to work too).
I never had problems with warping. I printed little shotglasses and chess pieces without problems. My rule of thumb is that the heat should be around 240-245C for ABS, and never print big or long prints.
Unfortunately my goal is to print enclosures, with a bottom area of about 100x100 mm and walls that may go up 100mm as well. This would probably be considered big compared to chess pieces and shotglasses :-)
mr_seeker 0
