Hi, Here are the latest error logs
2016-05-14 21:38:55,594 - DEBUG - Attempting to kill the engine process
2016-05-14 21:38:55,594 - DEBUG - Killing engine process
2016-05-14 21:38:55,595 - DEBUG - Engine process is killed. Recieved return code 3221225477
2016-05-14 21:38:55,595 - ERROR - A socket error caused the connection to be reset
2016-05-14 21:38:55,601 - INFO - Started engine process: F:\Program Files\Cura 2.1\CuraEngine.exe
2016-05-14 21:38:55,623 - DEBUG - Backend connected on port 49674
2016-05-14 21:38:56,136 - DEBUG - Sending data to engine for slicing.
2016-05-14 21:38:56,136 - DEBUG - Sending data to engine is completed
2016-05-14 21:39:00,957 - WARNING - Arcus Error (6, native 10054): Receiving type failed
2016-05-14 21:39:01,059 - DEBUG - Attempting to kill the engine process
2016-05-14 21:39:01,059 - DEBUG - Killing engine process
2016-05-14 21:39:01,059 - DEBUG - Engine process is killed. Recieved return code 3221225477
2016-05-14 21:39:01,059 - ERROR - A socket error caused the connection to be reset
2016-05-14 21:39:01,065 - INFO - Started engine process: F:\Program Files\Cura 2.1\CuraEngine.exe
2016-05-14 21:39:01,086 - DEBUG - Backend connected on port 49674
2016-05-14 21:39:01,608 - DEBUG - Sending data to engine for slicing.
2016-05-14 21:39:01,609 - DEBUG - Sending data to engine is completed
2016-05-14 21:39:03,792 - WARNING - Arcus Error (6, native 10054): Could not receive data for message
2016-05-14 21:39:03,894 - DEBUG - Attempting to kill the engine process
2016-05-14 21:39:03,894 - DEBUG - Killing engine process
2016-05-14 21:39:03,894 - DEBUG - Engine process is killed. Recieved return code 3221225477
2016-05-14 21:39:03,895 - ERROR - A socket error caused the connection to be reset
2016-05-14 21:39:03,900 - INFO - Started engine process: F:\Program Files\Cura 2.1\CuraEngine.exe
2016-05-14 21:39:03,922 - DEBUG - Backend connected on port 49674
2016-05-14 21:39:04,433 - DEBUG - Sending data to engine for slicing.
2016-05-14 21:39:04,434 - DEBUG - Sending data to engine is completed
nallath 1,117
Send us the gui & engine logs
See https://github.com/ultimaker/cura#logging-issues for more info.
