I checked the manual. I am aware to set the speed down. But I only want to say:
Movement <5mm f=20mm. Movement > 5mm f 40.
Ok, now I understand what you mean.
I am not aware of such a functionality in Cura. But it is a nice idea for a plugin.
Alright.
So can you tell me how are you printing so small things in a bigger area? The problem is, if I set the feed rate down, it takes a long time. If I use the standard feed rate, the holes in the 1st layer are not perfect all time.
Nicolinux 287
and welcome to the forum.
Sure it is possible to print slower. Take a look at the Cura manual:
https://ultimaker.com/en/resources/16586-basic
Also check the "advanced" tab. There you can set different speeds for different movements.
