I guess a good solid structure is the base of a good printer, so I would want to use the correct parts....
If you'r in the US try getting the parts from http://fbrc8.com/ (the US assembly partner of Ultimaker).
I general, to know which part goes where the .step files of the models are the best....
here you find the assembly step for the UM2 and the UMO (yeah the last one should probably not be there...) the DXF files of the panels are also available....
https://github.com/Ultimaker/Ultimaker2
and the GO
https://github.com/Ultimaker/Ultimaker2Go/tree/master/3D%20model
and the extended
https://github.com/Ultimaker/Ultimaker2Extended/tree/master/3D%20model
The step file assemblies contain the part-numbers, that correspond with the BOM and the pdf/DXF/Step files
If you don't have software that loads .step files try Design Spark Mechanical, or Autodesk Fusion 360 (cloud) both are free.
Fruition_Factory 0
Not even building yet and i found my first hiccup. The BOM calls for 40 DIN 562 Square Nut M3 A2, nearly impossible to find in the US. I can find the DIN 557's easy but they are 5mm not 5.5mm across. Anybody know what they go to and if the .5mm is going to make a difference? I am assuming they screw the frame together but want to make sure.
