You will need to have another firmware installed, i think that tinkergnome has a build for a dual UM2 (not sure).
For the material you will need:
1 feeder with motor
1 temp sensor
1 heater
1 head (spring, teflon, steel coupler, heat chamber)
But if you want my opinion just adding a second nozzle will probably be a lot of trouble for results that wont make you happy, but you can do it if you want
DidierKlein 729
1 feeder with motor
1 temp sensor
1 heater
