Netfabb GCODE via Printrun/Pronterface
cyclone
Posted · Netfabb GCODE via Printrun/Pronterface
I've noticed the latest Pronterface's new-ish time estimation algo barfs on Netfabb code.
It seems the offending line is:
G1 E0.0000
Is anyone aware of how to fix this in Netfabb as it seems to be a useless possibly malformed G1. (It would be nice
if Printrun did a little error checking of its input.) I'm sure Printrun expects an XYZ if there is anything.
Also It's part of the generated code and not something I can take out of the "Start" section of Machine. i
-b
    "G1 E0.0000" is fine as GCode so it must be the Pronterface that cannot handle it correctly. You should file a bug at the github project, it will most likely get fixed then.
