Which rod goes with which axis?
Lemma
Posted · Which rod goes with which axis?
Hello UM community,
I just bought a UM2 on eBay and when it arrived both rods holding the printhead had detached, I noticed that one is slightly longer than the other.
Which axis does the longer rod go with? Front/back or left/right?
Thanks!
    Can you not just hold them in place inside the frame an check? it should be fairly obvious...
    They both fit in both ways.
    The X is the shorter of the two, as verified in these two documents.
    https://github.com/Ultimaker/Ultimaker2/blob/master/1012_X-linear_shaft_(x2)/B1012-A2P-A.PDF
    https://github.com/Ultimaker/Ultimaker2/blob/master/1011_Y-linear_shaft_(x2)/B1011-A2P-A.PDF
    I assume the X axis is the left/right one based on what I see in Cura and common sense?
