One case is if the file name fore your model is not in alphabet, Cura gives you with that error. My first language is Korean and had to spend some time trying to figure out what the problem is with the model, turned out to be the file name.
I get these errors quite a bit, but it normally works after a couple of retires. No changes to input data, not running out of RAM.
Daid 303
Could be that you're running out of memory, or that something in the model is broken, or that part of the path has a none-ascii character.
I've updated the code for the next version, which will log more in case of errors.
