"Alright" you say, "what am I supposed to do, to generate the CAD design for these circuit boards?" "Surely you don't suggest I draw them with a 3D printing CAD software, trace by laborious trace?" Right! I did do that for the test circuit board in OpenSCAD, and boy was it a labor of love AKA a pain in the rear! "There must be a better way!", I thought. And there was.
First let me say that what is really and truly needed is a Gerber to STL or even Gerber to gCode translation utility. That's not so super difficult to make as Gerbers are basically mostly of the format go here in (X, Y) then go there in (X, Y) and so on, and both STL and gCode can be represented like that.
So certainly there may be in existence or will soon exist such software. I could not find it with a quick Google search anyway, so I developed a point and click workflow that is certainly a kludge but does get the job done for now. It goes like this.
You begin by designing your PCB in your favorite flavor of PCB CAD tool (I chose Eagle), then the first piece of jujitsu is you save the layers to file in PDF format. At least that's how I could do it with Eagle. After that my second piece of jujitsu is to double click on each PDF file and use Preview (I'm on a Mac) to export the PDF file as a PNG file. You may generate the PDF file another way and that's fine.
Then for my third piece of jujitsu I read those PNG files into OpenSCAD and saved them as STL files, so I have three STL files at that point. For the final piece of jujitsu I generate the each layer of conductor and difference() image of insulator for each layer, resulting in six separate STL files.
Now with those six STL files, we can print them all, insulator first and conductor second for best quality results (i think so anyway), or we can combine the first two conductor and the first two insulator layers, print the conductor layers first, , then finally print the third conductor layer and skip the third insulating layer altogether, resulting in only three print steps for a two layer board. I found that combo approach to be confusing mentally and lower quality in print form because of all the Zhop-hop-hopping around leaving angel hare (also known as boogers) all over the board, which we really cannot tolerate because it shorts the conductors.
Well there is one final tip in this crude and not-really-complete description, which is that we need sockets for our chips. The crudeness of the 0.4mm nozzle, a necessary minimum for the conductive filament to work (preferably 0.6mm), does not really support pin insertion and nor does it grab into the pins, so some type of friction fit socket is useful here.
I'm still working on that, for now I'm just adding large pin blocks that are spaced closely enough for a chip to be inserted either upside down or with the legs folded beneath it or trimmed with flush cutters and forced into the friction fit socket. More to follow on that technique and how to introduce it into the CAD files as a seventh layer (using custom footprints in the PCB CAD software).
So by now you've got the jist of it, you are a new jujitsu apprentice and you have at least an approximate understanding of that to do. Details and specifics to follow.
Les
Les go practice our CAD jujitsu!
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
LesHall 95
Les
