How to install cura-engine in Cent OS?
Jorgecuevas
Posted · How to install cura-engine in Cent OS?
I'm struggling installing cura-engine on a Cent OS based system.
On an Ubuntu based machine, it installs with the command
sudo apt-get install cura-engine
On Cent OS it should install with
sudo yum install cura-engine
, but the repository does not exist so I get the following error on the log:
No package cura-engine available
How can I add the package to Cent OS?
Is there another way to install it?
As a last resort due to the waste of space, will I be able to run cura-engine if I install the whole Cura including the GUI?
    Saw your PR on GitHub - well done.
    But there are some questions left...
    Why do you install all dependencies via yum? cura-build is able to compile all of them for you. Of course this is not needed, but this way you can be sure that you are running under the same tested conditions (while thinking of the dependencies).
    But so far, thank you for sharing your experiences with us.
        • 21 replies
