Strange flat top surface in cura 2.1.0
RonanB
Posted · Strange flat top surface in cura 2.1.0
Hi guys!
I have an issue with cura. It is maybe just a checkbox parameter somewhere but i can't find it...
So, i'm trying to print some molds, but when cura slice it, the flat surface which is in contact with the other part of the mold is not a full layer (i get a half layer most of the time). There is a gap of 0.2 mm on a large part of the mold.
The mold works but i really want to know why cura is doing that.
Here some pictures :
The object is touching the buildplate everywhere, so i don't think it is a problem of angle. Also with a 1° angle, i may not have those lines (in red on the second pictures)
On the last pictures, this is the problem on a previus mold.
Do you have some idea ?cura parameters, cura bug, or just a bad modelization ?
thanks for reading !
Ronan
