Bottom of print not as expected
Posted (edited) · Bottom of print not as expected
Hi all,
I'm hoping someone can explain what I am doing wrong here.
I uploaded some images in an Imgur album here:
http://imgur.com/a/59BUP
As you can see, one of the flat sides is filled solid, without gaps. This is the top side of the print.
But the other one has a lot of space between the lines, and irregularities. This is the bottom side of the print.
The last picture is from the side.
I'm using a UM2 with the following settings:
http://imgur.com/a/sxYF6
I don't understand why the bottom side is so rough compared to the top side.
Can anyone shed some light on how/why this is happening?
Thanks in advance!
    Posted · Bottom of print not as expected
    Hi and welcome,
    I think that you need to level the build plate a bit closer to the nozzle.
    The first layer needs to be squished more. In your case it looks like the first layer is not squished but rather "layed".
    The first layer in your case looks like the lines are piece of round filament, it needs to be flat.
    If the first layer is almost transparent you are to close, if the lines are not closed you are to far.
    More information can be found here
    Hi DidierKlein,
    Thanks for your reply. This does make a lot of sense. I'll re-calibrate the build plate and give it another shot. I'll let you know the results.
    You are welcome :)
    Also if possible please upload your next pictures directly on the forum (Go to albums in your profile and upload pictures there and the use the image gallery button here on the forum :)
    Good luck with your next print!
