Posted
· How do I launch Cure with a specified file.
Do you mean cura or the cura engine?
In case of cura; cura filename.stl
In case of curaEngine;
CuraEngine slice [-v] [-p] [-j ] [-s =] [-g] [-e] [-o ] [-l ] [--next] -v Increase the verbose level (show log messages). -p Log progress information. -j Load settings.def.json file to register all settings and their defaults. -s = Set a setting to a value for the last supplied object, extruder train, or general settings. -l Load an STL model. -g Switch setting focus to the current mesh group only. Used for one-at-a-time printing. -e Switch setting focus to the extruder train with the given number. --next Generate gcode for the previously supplied mesh group and append that to the gcode of further models for one-at-a-time printing. -o Specify a file to which to write the generated gcode. The settings are appended to the last supplied object:CuraEngine slice [general settings] -g [current group settings] -e0 [extruder train 0 settings] -l obj_inheriting_from_last_extruder_train.stl [object settings] --next [next group settings] ... etc.In order to load machine definitions from custom locations, you need to create the environment variable CURA_ENGINE_SEARCH_PATH, which should contain all search paths delimited by a (semi-)colon.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
nallath 1,067
