Check the settings in Cura, if you're using 15.x in the advance tab check to see that the infill speed is NOT set significantly higher than your standard print speed. The faster speed at the normal temperature can cause underextrusion.
Cura had the default infill speed at 85 for some reason for the longest time so printing at 210C on large parts will cause problems.
Also if you want alternating layers for infill, set your infill to 25% or higher and you will get alternating parallel lines that are 2x as tight instead of squares.
Alternatively, downloading the new CURA 2.1.x, you can choose the method of infill.
Also, great to see an UMO. your acrylic board is superbly clean for being 5yrs old.
Ultimaker + Cura. I don't think it gets any easier than this. I've tried using a Leapfrog and its slicing software, and it takes FOREVER, if it finishes at all! The printer, however, seems reliable enough. One day I'll try to figure out how to get Cura to talk to it.
valcrow 145
Edited by GuestLink to post
prather 0
Thanks! I'll try that next print.
