Lifesize Halo Needler Gun with Light Effects and airbrushed!
To be honest for the blue lights with the solid casings they are absolutely fine, but the pink 5mm LEDs for the needles are too weak for sure. In the original instructions on thingiverse the guy uses some 11,1V 10mm LEDs that were not available overhere, which is why I searched for an alternative. I guess for most projects you cannot beat the price of the ones I ended up using and you can easily use them with two AA batteries at 3,2-3,3V without having to solder some resistor in between.
For the finishing I always use laminating epoxy resin and automotive putty and then 240-600 Grid sandpaper. It still takes forever to sand everything if you print at 0.15 - 0.2 mm.
If i want the surface to be even smoother, I use some primer and then sand that even more.
I put them on display in my appartment actually. At the moment the needler sits right next to the Captain Phasma helmet :)No, I dont go to any cons, but maybe if I am able to complete any sort of costume, I will dress up for carneval
PrintingRevo 3
Thank you, Sander. It was a lot of work, but definitely worth the effort in the end
These are the LEDs I have at the moment:
https://www.amazon.de/gp/product/B00N9WEY0S/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Edited by GuestLink to post
