I am seeing the same behavior. I uninstalled 2.1.2 & downloaded a newer version that contained the Monoprice Select Mini profile. It launched once & then crashed. It will not launch again.
I installed Monoprice_select_mini_platform.stl in resourses/meshes & now Cura 2.1.2 launches.
Thanks to Eric Yeh,
kev
DaHai8 73
Have you tried any of the Cura included json files?
Because it sounds like the one you got from facebook is either corrupt or incomplete or not compatible.
