Screen v gCode Layers v Pause at Height
DaHai8
Posted · Screen v gCode Layers v Pause at Height
Riddle me this:
Why do the Cura Screen Layers start at 1 while the gCode Layers start at 0 (zero)?
Why does the "Pause at Height" Post Processing Extension use millimeters instead of Layer Numbers?
Basically, the way it stands right now, if I want to pause the print at a particular height to change filament I must:
1. Enable Layer View in Cura and note the layer number I want to print with the new color on.
2. Subtract 1 from that because gcode layers numbers start at 0 while Cura layers start at 1
3. Save the gcode out to disk.
4. Search for that Layer # and write down the Z height it prints at
5. Delete the gcode save in step 3
6. Go back into Cura and edit the Pause at Height to insert the correct Z height in MM
7. Save the gCode again and print it.
I'm thinking that if Cura starting number layers in the Layer view at 0 and the Pause at Height plugin used layer numbers, it would make swapping filament and the like a whole lot easier.
Or am I missing something supidfyingly obvious?
    Mmmh ...
    doing a little mathematics would make the life easier ;-)
    Assuming you have the following in your print profile:
    Layer Height: 0.1mm
    Initial Layer Height: 0.2mm
    No you want to Pause at Height at Layer No 10
    So you have 1 x 0.2 + 9 x 0.1 = 1.1 mm
    No fiddling with layer numbers and so on needed ...
    Shure, you're right, "why should we have to" do such calculations when a clever software can do this automaticly.
    I only want to show that the 7 steps in your post are not necessary if you do a little math ...
    Posted (edited) · Screen v gCode Layers v Pause at Height
    Well, to paraphrase Barbie "Math is hard" :), so I wrote a new plugin: Pause at Layer
    Ok, basically I just took Pause at Height and modified it to work off Cura GUI Layer numbers instead of Z mm values....
    For anyone interested, I'm happy to share the code here or anywhere it is appropriate to do so. Just let me know.
    Example print:
    I didn't get all the Black out of the print head before printing with Golden, so there's a bit of a bleed-in between the two. My bad, not the plugin's.
