Labern 774
Most greases will do.
Magnalube is a very good Teflon grease with a good life span which is not soap based.
I you use a different type you may need to reapply it more often or you may find the oil separates and leaves a thick soap on the thread.
Small magna lube tubes can be found on ebay.
