Cooling fans not spinning to cool controller board
KASHMIR
Posted (edited) · Cooling fans not spinning to cool controller board
Hi
I want to cool my ultimaker 2 controller board. So i designed a housing
to hold 2 fans 50mm x 50mm. These are SUNON fans
12v  1.26 amps each. I have connected both fans together, positive wire from one fan
together with the negative wire from the other. the other 2 wires plus and minus are
with connector. When i plug the connector to the board marked ( FAN 19-24 V )
and power it up, the fans dont spin. I see that the fans are trying to spin, but ever so slowly,
barely nothing but trying. Am i doing something wrong ?? I am not that electronic tech savvy.
Can someone please help me.
I have attached a picture.
Thanks
    Posted · Cooling fans not spinning to cool controller board
    So you got a china board and it doesn't work... Well, that can happen.
    Also, try the direct power 2 pins near the plug. You can't just plug any fan and hope it works.
    I tried connecting it to the other one that you showed in the image, but the fans still do not turn, can you please help me. i don't know why, it should work.
    is there something i have to add in the circuit of the fans ??
    and the fans have 1.26 watts output not 1.26 amps.
        • 24 replies
