Yes that the build plate wizard in the maintenance area. It's actually just gone and when I go to the area where it was it just doesn't do anything. Should I reload the firmware? I didn't initially want to do that Incase there was a step I missed to bring that back first.
SandervG 1,499
Hi @Jtn7040, welcome to the forums!
hmm, could you elaborate on what you mean by the auto level assist bedplate option?
Do you mean the option when you go to maintenance, and select build plate you will be guided through a wizard that will help you level your bed?
What happens when you go to maintenance, what are your options then?
