https://www.youmagine.com/designs/wedgebot-for-ultimaker2
My method is to stick this thing in the feeder just before the part with the blob and string is reaching the feeder and than manually pull out the filament. Works perfect.
To resolve your current situation, just open the feeder and clean it. See here for help;
http://support.3dverkstan.se/article/64-disassembly-of-the-ultimaker-2-plus-feeder
Thanks Ultiarjan, I guess I didn't yet fully understand why these buttons / levers were there on the feeder where now I assume it enlarges the opening. So your trick seems to make perfect sense to avoid the problem I encountered, thanks for that.
Also the disassembly instructions seem very detailed, will look into that later this week.
Many thanks!
Yves
ultiarjan 1,209
