No Skin Combing - Minimum Travel Distance
DaHai8
Posted · No Skin Combing - Minimum Travel Distance
I like the 'No Skin' Combing' mode for Travel, but I have two suggestions for improvement:
1) Set a minimum travel distance for retraction on 'No Skin' combing. I feel it retracts way too much - often just to move the print head over to the next surface line. Being able to set a minimum travel amount before it retracts on a 'No Skin' comb would speed up prints while still eliminating those long nasty comb lines across the entire surface
2) Option to comb on only the surface skin: Currently 'No Skin' eliminates coming on all top and bottom layers, not just the outer ones. So if you have 3 top and 3 bottom layers, all six layers get the full 'no combing' treatment. This is great for translucent material, but colors like gray, black, etc. only need combing turned off on the first bottom layer and the last top layer.
Just some ideas.
        • 21 replies
