Some layer have underextrusion
drindt
Posted · Some layer have underextrusion
Hello,
i have used S3D for slicing a couple of stl's but i experienced some layers are have extreme underextrusion, the layer after are looking fine later. This is first happen with the use of S3D. Since i wasn't able to have usable results i switched back to cura. Some prints was successful and as expected. But randomly some prints now have same underextrusion as i first experienced from the use of S3D. Is it possible, that some settings are adjusted from the S3D gcode which are still set and lead to this issue? Or the feeder is broken? I need some advise in this case.
Thank you,
Daniel
