Thnks... i don't now the repository
I compared the versions of .h configuration file (with that of Cura 2) ... there are no difference.
But I did a test: open the hex file (Cura 2) Arduino and send in Ultimaker it is downloaded but the printer stops working. While the same file sent via Cura 2 makes it work.
I think that sends or compilation (in hex file) Arduino modified the file and makes it unreadable by Ultimaker
Moreover, the weight of the hex file created by Arduino is heavier than the hex file Cura 2
Ideas ???
Dim3nsioneer 551
Sounds as if the configuration is not set for an Ultimaker Original+. Best thing you can do is to compare the configuration.h of this special Marlin version with the configuration.h from the UMO+ repository line by line. There are special apps for this, e.g. Winmerge for Windows user. Make sure the configuration.h selects the correct components for e.g. display (Ulticontroller), for the board (Ultiboard 2.x) etc.
