Hey Lance, welcome to the forums.
Did you check all connections from/to the board? Maybe something is loose.
Other than that, you could do a factory reset on the printer (save your material profiles first if you have some).
Thanks Nicolinux! I appreciate the help. I have pulled the board out twice since first installing it and checked every connection. They are all in the right places and they are tight. I also tried to do the factory reset. When I do the reset, and it starts the leveling process, as soon as I get to the point of turning the dial to move the base plate, the printer freezes and says I have an x y something or other failure and it locks up. I figured maybe I need to update the firmware, but I can't get Cura to recognize the printer so I'm stuck. :( Any other ideas? I feel like I've tried just about everything.
Thanks!
Nicolinux 287
