Posted · Disable single stepper?
I want to disable the extruder stepper in the middle of a print in order to switch the filament to a different color. Is there a gcode command, or sequence of gcode commands, I could issue to disable the extruder stepper while leaving the other axes energized (so they are not accidently moved).
Thanks,
Steve
