trouble with material flow?
bhotting
Posted · trouble with material flow?
hi,
I have some trouble with my ultimaker 2.
when i set the bottom layer to 0.1mm i get gaps in what should be solid.
see image attached.
when i set it to 0,3mm it works fine.
bottom speed is 15mm/s so not vast.
material is PLA
Any ideas?
looks like material flow is not enough or is there a known issue with cura v15.02.1 ?
thanks,
    When you print 0.1 if your first layer is 0.1 you need to do a very very fine calibration. At 0.3 the first layer has more room for error. Try using a bigger firstlayer or adjusting the thumb screws equally so the bed is closer to the nozzle.
