You can take a look at the platform attachment to the bearings by simply removing the two screws that secure the cover (where "Ultimaker 2" is written).To locate those two screws, take a look below the plate.
OK, undid the screws. The plate took a bit of prying to get up but underneath there didn't seem to be any problems:
The other place I looked is the Z switch recessed down in the bottom. I wondered if some debris had got in there but it doesn't seem like it.
Could it even be some weird software problem where it's not remembering the number of Z steps to the top? I doubt it because it happened spontaneously.
The only other thing I can think of is that when the plate rises it's fairly quiet but when it lowers there's a bit of crackling noise. I haven't had a *good* look around the Z stepper motor and Z switch since I've not removed the base plate yet.
Melka 57
Edited by Guesttypo
