renaming the folder and restarting Cura software solved the issue. Thank you very much! Do you still want to check some files for debugging?
Yes, that would be helpful for the devs in case they have not reproduced the issue themselves.
I sent a link via pm to download the zip file.
ahoeben 1,109
It would be very helpful in fixing this issue if you could zip up the C:\Users\Allinger\AppData\Local\cura folder and make it available for download somewhere.
In all likelyhood, you can get it running if you rename C:\Users\Allinger\AppData\Local\cura to C:\Users\Allinger\AppData\Local\cura.bak.
Edited by GuestLink to post
