So then the question is - why is the filament diameter set in my filaments presets not overwriting the pre-defined value?
I'm guessing because it's something we haven't tested (as all of our machines use 2.85) and it's something that slipped through.
Changing the filament diameter in the machine should work.
nallath 1,067
There is always a pre-defined filament diameter. Every setting must have a default within Cura.
