prints not coming out right?
rainlei
Posted · prints not coming out right?
so im trying to print this 'coin' but it keeps messing up the edges, the shape is a basic cylinder with a simple clean cut out in the middle.
but it keeps coming out like this
14795836_1079349662114276_1132379539_o.thumb.jpg.6d772dda91bc6f047af1155e1a76d046.jpg
any help in fixing the edges and bottoms would be appreciated!
    can you share more information about what printer/slicer you use and the material settings like material, temp., speed, layer height...etc.?
    What is the bottom part of the print? small or wide?
    Posted (edited) · prints not coming out right?
    the bottom is narrower then the top even though its spoused to be even.
    i have also tried every type of base, raft, brim, and skirt.
    also tried layer height of 0.06 which is default.
