Hi Les,
Do you need any help to rule out any of the above reasons?
HI Sander,
First let me express my thankfulness to y ou for all the dedication you put into this forum. I have recently coined the phrase "A 3D printer is only as good as the community behind it", and you are a cornerstone of this community.
I think it's the extruder being too tight because when I first got the printer I took apart the extruder - without reading instructions (!) because there was a clog in the Bowden tube caused by the printhead wire bundle tangling with the filament. Also the Proto-pasta Conductive filament I am using is very brittle and kind of soft too because the filler material is some kind of carbon stuff.
I was printing these same circuit structures with PETG and had no problems - quite beautiful prints too. Now I have cleaned out the hot end with cleaning filament which took forever as the cleaning filament kept coming out grey. Maybe that was the problem. Anyway I am trying the Functionalize Conductive filament which contains Graphene. It's much lower resistance.
Will keep you posted!
Les
SandervG 1,499
Hi Les,
Thank you for your post.
I don't think it is necessary to delete and reinstall Cura when your filament grinds. Is there a reason why you think it is required?
Grinding of filament can have different reasons. It can be that, like you say, your extruder is too tight, or something made sure the filament couldn't move back or forth. The latter could be due to an obstruction near the hot end, like a narrow PTFE coupler or a clogged nozzle, an inconsistent diameter or dirt in your bowden tube, or maybe the filament got tangled up near the reel itself and prevented it from moving up. I would suggest to look into these reasons if you want to find out the reason.
Depending on how properly you cleaned your bowden / extruder after the first clog, it could be plausible that your 2nd attempt carried dirt from your first clog in the bowden tube or nozzle.
I don't have any experience with this filament myself, so I don't know if it is more prone to clogging than other filament, or how consistent the diameter is usually.
