Layers is not generated when model i laying flat
holtz_dk
Posted · Layers is not generated when model i laying flat
Hallo fellow printers
I have a strange problem. I have not been able to solve.
I have a file from thingsgivers.com of a door to a board game. When the .stl file in Cura is standing up, no problem, the model printed nice.
When I lay it flat on the buildplate, to make it easier to print, layer 17-19 disapers. This means that layer 20 is being printer in thin air, and the result is not good. I have tried in Cura 15.04.6 and also in the new Cura 2.3.0 the same result.
I have inspected the .stl file nothing is missing, and also have tried to draw the door from scrach, same result.
Anybody got an idear. Thanks
    Posted (edited) · Layers is not generated when model i laying flat
    The object, closed door, has errors on the STL, that not even Cura can fix.
    5a332390995b4_Capturadepantalla2016-11-11alas9_33_11.thumb.png.e3854731669cc7707062dbce3059ea51.png
    On S3D (that is worse fixing bad STL) it shows errors on some points
    5a332390be44e_Capturadepantalla2016-11-11alas9_36_27.thumb.png.6b53cc4f3410da6739ea6f6dd00eb39c.png
    After using netfabb the file can work on Cura perfectly. So download netfabb basic, is a free trial that should fix your problem.
    5a332390e0793_Capturadepantalla2016-11-11alas9_38_06.thumb.png.f5fd49c56ade9d88e8987a5c65cd66d4.png
    I left you the file fixed on my dropbox, will be online just for today
    https://www.dropbox.com/s/52ju8cuq12asucs/Imperial_Assault_Door_Closed-repair.stl?dl=0
        • 24 replies
