Can't create material-profiles in Cura 2.3.1
maurice
Posted · Can't create material-profiles in Cura 2.3.1
Cura 2.3.1 gives us the option to create our own material-profiles by duplicating, renaming and changing, but they disappear from the list of materials, and when you change to a different material this newly made material-profile is lost. The profiles option does work, although it does not import the profiles made in Cura 2.1.3. (MacOS)
    • 1 month later...
