Can you remove the USB during printing?
cwsutherland
Posted · Can you remove the USB during printing?
We are only able to print via a USB at the moment. I'm wondering if the USB stick with the print file needs to be attached to the machine for the full duration of the print or if it can be removed once the print starts.
    • 5 years later...
    AFAIK, this has not changed. Printing from the USB key does not get much attention from Ultimaker, since the intended usecase is to use Digital Factory network printing.
