Ultimaker 2 grinding sound y-axis
wlaagewaard
Posted · Ultimaker 2 grinding sound y-axis
lately i have a grinding sound on the Y-axis. It stops making that sound after 30 minutes. I have read alot of aligning the Y-axis rod, but for the ultimaker 2 there arent alot of topics on it. The only change is that lately i print on 0.2 mm layer height. I tried to tighten de pullies, but it keeps coming back. Anyone have a clue?
    There's a few things you can do;
    - lubricate the axis with some sewing-machine oil.
    - check the alignment of the axis, read how to here;
    https://ultimaker.com/en/resources/19953-aligning-the-axles
    - take out the head, and slide an axis manually thru the bearing, to feel if the bearing is not damaged.
